CPU/Mobo Help me connect the Front pannel audio connections
ubergeek
Forerunner
As you all know if you had visited my previous thread i recently changed my MOBO
every thing went smooth except for the front pannel connections
I got the LED's and reset power switch rite except for
Here is the diagram from the manual
[attachment=11056:Front pannel audio.JPG]
Here is the connectors that ar availlable with my zebby peace
R ret
R out
Lret
Lout
Mic Power
Mic-IN
GND
can some one tell me which one goes where?
I just posted the usual pin config and changed the pin names as per your mobo. Most of the cabinets have same pin name as you mentioned.
dude if i connect my hEad phone to the fron pannel sound is only comming from the right side
Usually in most of the chassis, all the 9 audio wires are joined together into one single connector, which fits only in one way to the lack of one hole.
Do check your chassis front-panal connector. If possible post a snap as well
Pin 1 Port1L - MIC Power (L)
Pin 2 Ground - GND
Pin 3 Port1R - MIC IN(R)
Pin 4 Presence#
Pin 5 Port2R - LINE OUT FR
Pin 6 Sense1_Ret - LINE OUT RR
Pin 7 Sense-Send
Pin 8 No pin
Pin 9 Port2L - LINE OUT FL
Pin 10 Sense2_Ret- LINE OUT RL
