sudhanshu123
Contributor
I didnt know where to put this thread so put it here mods,please move it to the right section if this is wrong.thanks.
ohk guys as the topic suggests i bought myself new pc parts and assembled it day before yesterday and now i have got this problem(and its sucking the life out of me).i will just be explaining the problem and asking for help but i want to tell you that all the components bought were ordered off flipkart(i dunno if this was foolish,and also if anything does turn out faulty please please tell me how to avail warranty,i have all the bills with me)So with that out of the way i will tell all the components ordered :
Biostar TA990FXE- MOBO
AMD FX 8120 - PROCESSOR
Asus GTX 560 Ti DirectCU II- GPU
CORSAIR vengeance 4GB-RAM
Gskill Ripjaws 2GB -RAM
CM 430 Elite -CABINET
Seasonic S12II 520W -PSU
I already had a 500GB HDD and an optical drive so used them in assembling the pc together.
PROBLEM:So when i assembled the PC day before yesterday,it started out fine.Formatted the HDD and installed fresh windows 7.Then yesterday i wanted to oc the proccy,so went in the bios,set the multiplier 20x(the BCLK was 200) and set the cpu voltage to 1.3v.Did not fiddle with any other setting other than disabling any and all options which downcored or reduced cpu frequency for saving power.Then saved the settings and restarted the pc.
Upon restarting the PC did not POST,so turned the PC off by switching the PSU off.Then when i turned the switch on to start the PC up again nothing happened.Just no light turning on,the front light on the case did not turn on and no lights turning on,on the mobo.So i tried switching the psu on and off a couple times,checking the cable connecting the PSU to the AC wall socket but still nothing,the PC just stays "dead".so i bring my other PSU(very old but known to be working) to test it.Now this psu had all the connectors i needed to test my PC but it had only a 4PIN ATX power connector but my mobo takes a 8PIN ATX power connector so i didnt connect it.Connected the 24/20 Pin power connector on the mobo and tested for any light turning on but still nothing.So is the 8pin ATX power connector necessary for turning front panel lights on?also tried clearing the CMOS(but how could this have any effect, right?),took out the battery for some time but still nothing.
ohk anyway,so here i stand-With a new PSU and a new mobo but nothing powering on.I dont think the psu is faulty because it worked alright for one day,so i suppose it cant go boom suddenly can it?and i have the same thoughts for the mobo.i am very tensed right now because i feel like i wasted all my money(and by law of E=MC^2,i could blow the universe up if i could).Please tell me guys if i have missed anything?what should i do?i dont have a multimeter to test the PSU.and also could trying to oc have any relation to this?i just want to see the pc up and alive again and also please tell me how one can avail warranty on products ordered by flipkart,i suppose an email to them would suffice?
