sagar.sdm
1. Q: What is your budget?
1. 25k excluding (a) monitor which I have bought already - P2250 (b) speakers, which I don't intend to buy now.
2. Q: What is your existing hardware configuration
1. Monitor - Samsung P2250
3. Q: Which hardware will you be keeping
1. Monitor - Samsung P2250 (Of course )
4. Q: Which hardware component are you looking to buy
1. CPU, mobo, GPU, RAM, SMPS, cabinet, DVD RW drive, Hdd, UPS, headphones
5. Q: Is this going to be your final configuration or you would be adding/upgrading a component in near future.
1. Yes, will buy good set of speakers later
2. If the present budget is low to include 4GB RAM and 1TB Hdd, might upgrade to them later as well.
3. headphones aren't necessary too if the budget is low.
* I intend to get best CPU, Mobo, GPU, SMPS combo now with no compromises*
6. Q: Where will you buy this hardware?
1. Bangalore
2. Open to online purchase, if warranty holds good (local preferably)
1. Yes, if its a good deal.
8. Q: What is your intended use for this PC/hardware (in decending preference)
1. Watching HD movies
2. Gaming
3. Desktop Processing
4. HTPC
5. Browsing
6. Download rig, 24x7 operation
1. No Preferences as such as long as they are best performers with good VFM.
1. Nothing specific, would try hands on many. (racing/first person shooting kind)
11. Q: What is your preferred monitor resolution for gaming and normal usage
1. Gaming - I'm not sure. The one on which I can run games smoothly on my rig.
2. Desktop - 1920x1080
1. Yes, may be after learning more about it, haven't tried so far though.
1. Windows 7 64 bit genuine which I got for free
2. Windows 7 32 bit ( should I install this apart from 64 bit ? skeptical here )
3. Linux distros (when needed, of course to learn basics in it to start with)
Ok.. So, please help me to choose the best. All suggestions welcome.
Thanks in advance.
1. Bangalore
2. Gaming
4. HTPC
5. Browsing
Thanks in advance.
