My friend wants to buy a PC for his Office use pleae help me out
1. Q: What is your budget?
1. around 28K
None
Not Applicable
1. CPU - Intel i3
2. Motherboard - any compatible motherboard having
3. GPU - not sure
4. cabinet - any good looking around 1.5k
5. HDD - 500 Gb Seagate
6. Monitor - 22'' samsung
7. HP Printer 2050
1. Yes, will upgrade the following after 2-3 years
1. Mumbai, Lamington Road
1. No
1. Gaming - not sure
2. Browsing
3. DTP ( corel draw, photoshop, reach fashion studio)
4. Download rig, 24x7 operation
5. Watching HD movies
1. no
1 No Plan of playing games
11. Q: What is your preferred monitor resolution for gaming and normal usage
Not sure
1. No
1. Windows 7 32 bit
2. Windows Xp
1. around 28K
None
Not Applicable
1. CPU - Intel i3
3. GPU - not sure
7. HP Printer 2050
1. No
2. Browsing
1. no
Not sure
1. No
1. Windows 7 32 bit
2. Windows Xp
