Any leads would be great. Can't seem to find this able anywhere in Mumbai.
y2s Disciple Nov 19, 2018 #1 Any leads would be great. Can't seem to find this able anywhere in Mumbai.
M Marcus Fenix Skilled Nov 19, 2018 #2 https://www.primeabgb.com/online-pr...c-25-pci-e-riser-cable-fd-acc-flex-vrc-25-bk/ Are you sure you want to go this route? It increases temps quite a bit as the intake fans are too close to the side panel.
y2s Disciple Nov 19, 2018 #3 I actually did find that link this morning, but alas when i called prime, they did not have it in stock and did not know where to source it from. Building in an open frame so airflow is not an issue. Thanks for the heads up though =)
nRiTeCh Skilled Nov 19, 2018 #4 Here these might help you: https://www.amazon.in/Micro-Express-Riser-Flexible-Extension/dp/B00D79EV0G?tag=googinhydr18418-21 https://www.banggood.in/19cm-PCI-E-...PCh2IUABcEAQYAyABEgKEx_D_BwE&cur_warehouse=CN https://www.amazon.in/Generic-PCI-E..._rd_t=40701&psc=1&refRID=DQMJVF1NPMFV6B48E6D6 https://www.amazon.in/Thermaltake-A..._rd_t=40701&psc=1&refRID=DQMJVF1NPMFV6B48E6D6 https://www.amazon.in/Express-Riser..._rd_t=40701&psc=1&refRID=DQMJVF1NPMFV6B48E6D6
vivek.krishnan BLR~ZRS-TX-1-MX Skilled Nov 20, 2018 #5 Use is for? I think @cyberwarfare was going to get these for a GPU. However, there were some issues with quality of stuff, maybe?
