i have a 4 partition in my hard drives which runs on a windows XP OS
.currently i am not able to access one of the partition.if i try to access the partition the system go to hang state.
go to command prompt and select the drive which u r facing the problem (if u can)run the chkdsk /r comand in it.it will ask u to select it on next restart.allow the system to scan on next reboot.This could help u to rectify this
