It's been just 4 days since I've been using Leopard, and I'm already loving it ... but I've got a few minor niggles that I'd like to be resolved
1) I'm not able to move a file from one location to other, I've to copy it and then delete it from the original location or use drag and drop, so is there a solution or a script to get the move option on the right click menu ??
2)I'm able to see all the hidden and protected files on the windows partition through finder, which I don't want to be able to do for obvious reasons hyeah: So what can be done about it ?
3)is there any way to increase the size of the os partition ?? had to format and install the whole thing again cause I was running out of space.
4)could you have finder display an address bar, like you get with windows explorer ?? (I googled and found that it isn't possible, but still asking ).
