help to fix ...brainwavz M3 driver problem
amolc193
Enclave Plus
Contributor
11227064
My brainwavz M3 's right side's driver has came out .. the metal part with diaphragm has separated from other part in plastic casing...did anybody had similar issue .... any way to fix it...
- - - Updated - - -
www1.picturepush.com/photo/a/11227064/img/11227064.jpg
@PristineNote is it repairable..
If only the housing of M3 was opened and had it been a manufacturing defect the M3 could be replaced in warranty but since the complete driver assembly has dismantled the same can not be replaced or repaired.
