hello,
my frnd is having this weird issue since last couple of days. after powering on the screen displays 'usb device overcurrent status detected...shutting down computer in 15 seconds' even before the bios screen comes up.
did a lot of searching on net but cudn't find any concrete solution. Some suggest to replace the cmos battery, some say it might be a shorting problem while a few other opine to downgrade the bios to an earlier version(when the bios screen ain't coming up how do u update/downgrade the bios?)...
if any of u hv faced the issue before it'd be nice of u to post the solution, if any( other than to RMA the board or taking the machine to the shop from where it was bought).
the machine was purchased abt a year back. its a amd 3000+(939), Asus a8v-vm mobo based one.
