help! USB problem
Doubleseven
Contributor
hey peeps..
got a weird problem..
whnever i connect a device to the USB port of my comp.. i dnt get an indication tht the device is connected.. no new hardware found message.. nothin
wht cud b the problem?>
i tried connecting my mobile phone, modem and a thumb drive..
help me out
thanks.. :)
goto device manager, uninstall the USB controllers.
they should b detected on the next reboot.
then, windows will install the usb drivers.
i once faced a similar prob, doing the above solved the prob.
