Linux Help with Ubuntu Audio
Spy king
Contributor
Hello!
I have a Ga G31 mobo, which uses the Realtek 883 audio chip..
In windows, the driver would automatically prompt which speaker goes into which jack..
Anyway, I can get my front speakers to work in Ubuntu 9.04, but the speakers plugged into the line-in jack ( the rear speakers ) don't get any output..
I'v tried searching the net and have reached quite a few How-to's.. none help.. the max I was able to achieve was the get pulse audio to show a rear channel along with the front channel.. but that was linked to to the same front speaker..
PS: I'm an absolute linux newbie.. just started yesterday.. :)
Thanks!
You could try searching for / installing the pulse audio mixer package - I think its "pavucontrol" but this is a real hot topic (audio under ubuntu) anyway heh...
wow! Darkstar! How did you get that!?!?
And yeah.. I'v been reading all night about ubuntu and sound :P I'v tried pulse audio, alsamixer.. Dunno what else to try,
Btw, Will Drivers from the realtek site help? it says it's for ubuntu, but I don't know how to compile it :(
Thanks!
hmm.. I got something diff than that.. lemme try again.. should i do it from the terminal or from the add/remove thing?
EDIT:
Here are the things I see via the add/remove thing
Pulse Audio Manager
Device Manager
Volume Control
Volume Meter(Capture)
Volume Meter(Playback)
EDIT2:
Well, I added a few lines to the pulseaudio config ( changed number of channels from 2 to 4) after reading a thread on ubuntuforums..
So now I see this, but both front and rear are linked to my front speakers..
Oh, And I just realised that the left/right balance is also not working. :( Other than the audio part, I'm really loving linux! If only I can get this to work..
Keep clicking around on a few more buttons (I dont remember the exact location) till you find the config window with a long list of outputs to select/unselect... you can enable your line-in/front/rear etc in there... like the screenshot DarkStar posted...
