mantheman
I wanted to know your suggestion on my access point setup, total area is ~38ft x 36ft.
1. I will be using Airtel Fiber or Jio Fiber (100Mbps plan the ~Rs.850 per month)
2. Is my access points overkill? The problem is I looked at a good design ethernet wall plate from Amazon and found out that its pretty costly so, maybe opt for EAP230-Wall for 2 rooms?
3. What switch should I buy? I wanted to power the 4 APs from POE, any suggestions for the switch? I don't know if ill be using Omada from my NAS, I can use, but dumb switch is preferred.
4. Any recommendations are welcome.
5. I have NAS and mini PC stuff.
