Audio How do I listen wirelessly over headphone to my newly purchased VU 40 inch basic HD led TV (not sma
sunandoghosh
How do I listen wirelessly over headphone to my newly purchased VU 40 inch basic HD led TV (not smart)?
Basically I have purchased new led TV vu 40 Inch from flipkart. All I want is to be able to hear wirelessly on headphones from this so that others are not disturbed by sound.
I have
Been reading but confused as it seems we have many options like RF IR BLUETOOTH and then analog digital coaxial audio output. Pls help as i mm. Not getting technically which is right way and what to purchase to listen. Also if two people could listen wirelessly same time that's greatgreat.
Exact model I purchased:
40D6575 LINK below
Vu 102cm (40) Full HD LED TV
Buy Vu 102cm (40) Full HD LED TV Online with BBD Offers! at best Prices In India
Also it seems only one headphone can connect to this device wirelessly. Any option for multiple headphones being connected to same device over Bluetooth.
I was also not sure but which one is superior RF or Bluetooth in terms of quality ease etc.Any suggestions there.
Kindly revert.
How often will want to listen wirelessly and how long each time ?
RF will have more range than bluetooth but the sound quality might not be as good. I think the bandwidth is less compared to BT. Depends wht kind of RF, check the specs.
multiple headphones work with pricier units.
