How to do that ?? Say.. i want to connect from my office pc ??Anish said:If somebody wants to connect to you remotely its very easy since your IP never changes.
Downside is, that if TE IP-Ban's you, then your screwed
broar94 said:^ that can be solved by visiting their home pages because your ID is linked with the tracker so it would be know
tarun said:Few examples:
Remote Access:
You can run a VNC Server on your home PC and from your office you can connect to your home PC by using VNC client. By using VNC you can have the total control on you PC by sitting remotely.
Try:
SourceForge.net: UltraVNC
Run a FTP Server:
You can run a FTP server on your home PC to share files and from the remote machine you connect to that server using a ftp client. You can download/upload files from/on your home PC.
Try:
FileZilla Homepage - Index
