PC Peripherals How is Cooler Master Hyper TX3 EVO Cooler
quan chi
Herald
My cpu temps are soaring up with the default coolers.Therefore will this cooler do any good to keep them at normal?
Which processor do you have? More information from your side will be helpful. The TX3 Evo is an affordable solution and performs better than the stock cooler. However if you plan to do a moderate overclock, i would suggest you check the Hyper 212 Evo - absolute bang for the buck!
Cheers
Sanket
