PC Peripherals How to attach fans?? No more sys fan headers
techygeek
Contributor
Hey
my problem is dat my case has 5 fans of which 2 have molex connectors and remaining 3 have 3 pin pwm connector.
but the problem is that my board has only 1 sys fan header where i have connected one of the fans
Now the question is how do i connect the remaining 2 fans???.
Guys plz help
thank you
You'll need a 2pin to 4pin - Molex fan connector. That way you'll be able to connect the fans to molex connectors.
This to be precise -
If you are a bit gutsy, then you can try making one with 2 small cables. Its quite simple really.
techygeek said:
Hey
Guys plz help
thank you
take a soldering iron, soldering supplies. take some wires. and connect all ur fans together. this opts for a more clean look. Also saves molex outputs. Don't use the third wire on these fans to connect to the sys header. you will get incorrect reading due to superposition of two pulses coming from two wires.
ok guys thanx for your suggestions....but can u tell me where can i get the connector mentioned by RD274 in mumbai...may be near borivali
