PC Peripherals How to Connect Cooler Master Excalibur 120 mm Case Fan
ganesh_2218
Forerunner
I bought used CM Excalibur 120 mm fan from Mav 2000 in TE Market. I have trouble in connecting the fan to my mobo. The cable that comes from fan has only 4 pin connector and the supplied cable is 3 to 4 pin molex connector. Where should i connect the fan wire.
Also which side should my fan face when mounting at my cabies side panel. My cabinet is ThermalTake M9.
Ganesh
