raja_mastana
Galvanizer
Uploaded with ImageShack.us
Description
PIR with Dusk to Dawn Function for Night Operation 110V-245V AC
By default, PIR function work during night time only. (Sensor can be made to operate in any condition (light/dark), by a simple DIY modification)
Useful for Stairways, Buildings, Path Lights, Gate Lights, Homes etc. For e.g. In your homes, you can use in your bathrooms, passage etc. As soon as the sensor detects a motion, the light connected to it will glow.
You can also attach it near the home entrance, so that whenever you walk it to your home at night, lights will automatically glow. No more finding the switch in the dark.
There are two adjustable knobs for setting the delay (Lights turn off after x seconds of inactivity) and darkness sensitivity (Light environment for Sensor to work)
Also contains two types of attachments for installation on wall - movable and fixed
Specs
Rated Voltage: 110V-245V
Resistive load <= 200W; Inductive Load <= 100W
Time delay: 6-180 seconds ( can be adjusted , default: 6 s )
Distance :7 Meter ( can be adjusted )
Trigger: Repeat Trigger
Detector range: 7M
Detector angle: 140° Cone Angle
Turn off during daylight
Lux Control: 5LUX-500LUX
Dimensions: 64.5 x 50.5 x 37 mm
Work temperature: - 20ËšC ~ + 50ËšC
Max Load : 200 Watt (Normal) 100Watt (Inductive)
Energy-saving lamps and fluorescent 5-100W
LED 6-50W
Incandescent 200W
Quote from supplier : 739.00 for 10+ pieces (incl shipping by SpeedPost)
