That should be just fine and the price also seems quiet good. Ive been using Su-Kam 1.4KV sine wave inverter for past 7 years and no problem as of year. The backup seems to be reducing after 7 years, so changed the batteries which is 2*120 Ah tubular ones each costing 11.5k (23k total). The 55k price for 4*150 Ah batteries plus the inverter unit seems really good. make sure the batteries are new and are of good make. Also there are 200Ah batteries available, which will be around 3~4k additional for each batteries than 150Ah, and it ll give far better backup hours. So <70k for 3kVA with 4 200Ah tubular will be awesome.
About maintenance, you should bother about it for atleast 2~3 years, after that just a checkup of batteries and just refill with distilled water will be required and same has to be performed every 2~2.5yrs.
Also avoid VX450 PSU for the system if used with those inverters
. VX550 is fine, and all above models from major brands seems fine.
