PC Peripherals Is my new system running hot? plz help
Sandeep_th
Beginner
Guys....
Please take a look at the temp and suggest if this is normal which i doubt, what should i do?
Hardware monitor
ACPI hardware monitor
Temperature sensor 0 37°C (98°F) [0xC1E] (THRM)
Dump hardware monitor
Hardware monitor
AMD Phenom II Black Edition hardware monitor
Temperature sensor 0 36°C (97°F) [0x123] (Core #0)
Temperature sensor 1 36°C (97°F) [0x123] (Core #1)
Hardware monitor
ATI Radeon HD 4800 Series hardware monitor
Voltage sensor 0 1.12 Volts [0x1] (GPU Core)
Temperature sensor 0 53°C (127°F) [0x35] (GPU Core)
Hardware monitor
WDC WD5000AACS-00G8B1 hardware monitor
Temperature sensor 0 34°C (93°F) [0x22] (HDD)
please suggest what to do?
Guys...
the temps on the GPU are averaging at 80c after playing games for like 30 minutes... should i replace the stock cooler. I would prefer the temps to be well within 60c.
Any recommendations
Thanks again
Sandeep_th said:
Guys...
Any recommendations
Thanks again
try increasing the fan speed in catalyst control center...
Well this are good temps, however I think this are Idle temps, What are the load temps, try running orthos,e.t.c as well as heavy strategy games with loads of particles and full shraders and possibly a big map with lots of people.
Also if you feel the temps are high than I suggest you use MX-2 or any non-conductive ceramic, I think you can also use OCZ Freeze. Apply on the North Bridge, South Bridge, CPU as well as GPU.
The temps should go down more. I like to see load temps at 40.
