ss_rakesh said:My RS1500 has CSB battery CSB Battery HR1234W F2FR
but another UPS (RS1000) has exide with less voltage and current spec
Got an website which automatically display's equivalent batteries for CSB
Buy a cheap CSB HR1234WF2 PX12090 UP-RWA1245P1 BB HR9-12 HR8-12 Battery from MDS Battery
btw, is CSB avaialble in Bangalore?
ss_rakesh said:One of the shop person told me that Panasonic closed business.
And exide they have a Sealed Lead Acid-12v-28w, 48w, batteries and my battery is Sealed Lead Acid-12v-34w.
So, What parameters Do I need to compare with my old battery, If I decided to Go for a higher wattage, I am even not worried about space issues
btw, which is the best shop in Bangalore to buy Exide batteries?
Update: just got this website BuyBatteryOnline, is this reliable?
adder said:the apc also sells BR24bp a add on external battery pack of 18ah 24v(consists of 4x 9ah 12v batteries) costs 4.2k.
Thirumala Enterprisesadder said:well u can buy them from thirmula enterprises (consists of 4x 9ah 12v batteries) costs 4.2k.
well u can do that but the charge time will be higher.but only pros of the apc battery pack is that it looks good and blends in with the ups,but for the same price u can get much more power full quanta batteries i.e a pair of 26ah batteries.ss_rakesh said:More confusion, how about buying another addon pack and connect to internal battery pack connector ppo:
No.465, 17th Cross, Tank Bund Rd, Malleswaram West, Bangalore - 560055 ?
