Jiofiber not working when running torrent
I don't know if its possible on your router but you can try to lower security level (not exactly sure what it does imo, some kind of firewall thing?). This should reduce taxing of CPU if it was contributing to it and unless you are into networks and know you need that kind of security it won't matter.
Edit: forgot to mention, have you tried just running tcp or utp instead of both?
I disabled ddos and syn attack.. but nothing happens.
Did not try tcp or udp..
I have the same issue. Not only with torrents but with every heavy download. If using any download managers, the internet stops working. It's the shitty router.
Reactions: r4hul
Hey even i am facing the same issue whenever i download any game via torrent file the internet stops working on the other devices did you get any solution to fix it??
Two solutions. 1) ask joi to change the router(which will eventually fail as the router will upgrade it's firmware and same issue will come).
2) which I did :- bought gpon router.
Seems like Jio is throttling/blocking bitorrent traffic. These big name ISP's are very controlling,
You should consider swithing to a ISP that just provides a GPON and let you use your own router which you can configure as you please.
