Security Software kaspersky not starting
GODMODE09
Level D
Hi,
I have bought Kaspersky Internet security 2013 and it was working perfectly. But from the last 2 days , it did'nt start on start-up and from last night it's not starting at all.
I tried opening the application from start menu and it just says "loading" but noting happens and then it goes off again.
Not able 2 turn it on through Win7 action centre either.
Could my PC be under any attack ?
Thanks
Are you sure that you don't have any other security program that might conflict with your Kaspersky?
If you have recently removed any other security software then you can use Appremover (Uninstall McAfee, Symantec & other antivirus software with AppRemover) to remove any left overs.
Also download the GSI utility from http://www.getsysteminfo.com/ and use it to generate a system report and then upload it on the same site.
This will give you possible causes, incompatibility issues or any updates required, etc.
