Ok guys , my laptop was overheating so i took it to repair center to get the thermal paste applied and clean the dust .
In the process of cleaning the laptop FAN , the guy broke one of the fan vane (blade) ..
The fan is running fine as i can feel the hot air coming out and there is no large noise also , only thing is that i feel this is causing my laptop to vibrate ..
i dont have a problem with vibration , i just want to know if its okay for my laptop , i mean will constant vibration damage my motherboard or hdd ??
Thanks !!
Thanks !!
