windwithme
Herald
E7 version of be quiet! Straight Power series is the latest version launched by BQT.
The models from earlier E7 version are 480W, 580W and 680W.
These 3 models are all cable management (CM version) power supplies and surely their prices are a bit higher because of the relatively costly CM design.
Straight Power also has its non-CM version in the market, including 500 and 600W. In terms of selling prices in the market,
their prices are surely a few hundred bucks lower than that of E7 CM version.
The focus of new E7 version launched this time is on 80+ Bronze Certification and the SilentWings FDB fan integrated.
This new series not only is compliant to Rev. 5.0 of Energy Star and the power consumption needed in standby mode is less than 0.5W.
As for its cosmetic part, the point lies in its brand new style.
The case used this time is quite different from be quiet! typical image in our mind. We’ll introduce more of the case in the following section.
Here is our star, Straight Power E7 600W.
The color box design of E7 version, with less different color combinations, looks more elegant.
Contents
Multi-Language User Manual, Cable Ties, Screws, Power Cord.
Straight Power E7 600W Dimensions: 160mm X 150mm X 86mm
The coating is “finger-print resistantâ€, leaving the case a neat touch.
The titanium gray coating used this time makes this E7 version quite different from the black case we normally see in be quiet! power supply cases.
The honeycomb ventilation holes in the back side, commonly seen design.
Active PFC, 110~240Vac
The symmetric fan guard is in Jazz-Black. Just like what I’ve said before, it looks really like BBQ grill. However, it still looks quite stylish.
12cm FDB Fan: MTBF/300K hrs, 17dBA
The model name of Straight Power E7 600W is "BQT E7-600W"
+12V*4 (45A in total), reaching 540W at most.
3 rows of honeycomb ventilation holes right beside cables, quite helpful in enhancing the heat ventilation mechanism.
Output Cables
1 X 20+4 Pin ATX
1 X 12V P8
1 X 12V P4
1 X 6 Pin VGA
2 X 6+2 Pin VGA
4 X HDD
6 X SATA
1 X FDD
Contents
Output Cables
1 X 20+4 Pin ATX
1 X 12V P8
1 X 12V P4
1 X 6 Pin VGA
2 X 6+2 Pin VGA
4 X HDD
6 X SATA
1 X FDD
