Low sound from Edifier's C3 headphone output
andysmith45
Inactive
Contributor
The sound coming from my headphones when connected to edifier c3 headphone output is very low. One can barely hear anything at 30, and I have to increase the volume to 45 to enjoy the music. I would like to know if any of the other Edifier C3 owners have the same problem.
That is something even i am facing, but if you try to increase the master volume from the inbuilt sound manager in windows, the volume may just increase a bit.
I directly connect my headphones to my soundcard due to that very reason. And believe me, there is a hell of a difference. That is one -ve point from C3 amp, SQ is mediocre from the headphone output on the C3 amp.
I thought that my unit was defective and was about to take it for servicing. Since it seems that it is a design fault, I'm glad that I ask here first. Save me the hassle. Anyone one else having this problem?
No issues with the SQ coming from the speakers though. I just loved it. :hap2:
AS, I had owned Edifier C3 and difference is huge.
Thru soundcard, very good. Else, its ok from 40 I guess. I was then using the ASUS Xonar HDAV's stereo outputs.
Andy, even I've been facing this problem since I bought me set.
Nothing really you can do about it, just plug in your headphones in your soundcard.
