low speed on mtnl triband
vishalk
Inactive
Discoverer
Hi guys,
It seems something has messed up or what coz i'm on the 512k ul plan and was getting 2mbps since a year now and am suddenly today only getting 90 to 100k on a torrent and when i do a speedtest on speedtest.net it shows bandwidth much lesser then i should get, is any1 else facing this tto? i'm in mumbai.
consider urself lucky..
ur ideal speed should be hovering aroung 58-64kbps and not around 2 mbps. there was a loophole from mtnl side so ppl got undue advantage of it. now its rectified.
Be happy, nothing's wrong from ur side.
I had the same problem. Instead of calling it a loophole, I would call it a teaser speed just to lure customers to high speed plans.. :@
If you would have read your plan a bit more carefully, it said Upto 2mbps and minimum 512kbps. They have recently stopped that plan.
lol dunno what to say, called 1504 and they say that they've got a packet loss issue should be sorted by 8am tomm, would be glad if some1 could confirm this
