indieboy540
I've been trying forever but I can't seem to set up my wireless connection with Sify Broadband. According to my router manual I first make all the proper connections to my router (LAN wire into the router, RJ-45 wire from the router to the NIC, and the router plugged in and turned on). Then I go into my Network Settings and configure my TCP/IP settings to obtain the IP Automatically. This however creates a problem since the Sify BBC (Broadband Client) needs a specific IP that they provide. Anyways after that, I configure my router and select the PPPOE setting (I'm guessing that is what Sify uses since it prompts you for an account name and passoword). The I fire up Sify BBC and it freezed every single time. Any help would be very much appreciated. Thanks!
