amit_talkin
I m going to work on a water cooling project. making my own wc kit! I dont know I will succeed in this but I am trying my best to find out parts.
Parts I found.
1. 18w submersible pump ( very small in size, can circulate water up to 5 feet height ).
2. engine radiator ( found a radiator maker locally here, they can make any size radiators ).
3. 3x3x1 inch copper block ( give me some suggestion on this, how to make pole inside it ? or should get 2 copper plates/blocks and joint them? ).
4. tubes...
submersible pump works INSIDE water so it will be kept in reservoir.
here is the link for the pump
http://www.tullu.com/pump02_submersible.htm
give me some suggestions on parts .
Amit
Parts I found.
4. tubes...
Amit
