Futureized
Selecting mi brand for few reasons:
1. I can block any other calls, which are not on my contacts.
2. Can easily switch between 2 sim cards.
Questions:-
1. Budget?
A: INR 20k-25k (MAX)
2. Preferred display size, type and resolution?
A: Using Note 5 Pro at present, unsure about further enhancements.
3. Preferred operating system? (Android (with version), iOS, Windows Phone etc).
A: Android Kitkat (4.4) and above
4. Preferred connectivity options? (4G, 3G, 2G etc).
A: 4g ofcourse, but prefer if 5G compatible (NOT completely sure if should go for 5G)
5. Do you have any brand preference or dislike? Please name them.
A: Mi
6. What is your intended use for this phone (internet, camera, multimedia, mails etc.)?
A: Camera, mails, internet, multiple productivity apps.
7. Single SIM/ Dual SIM?
A: Dual Only,
8. New or Used? Online or Offline?
A: New. Don’t mind buying offline (only mumbai) or online
9. Any other requirements?
A: Need good battery backup,
Difference between 6GB/8GB ram unsure. If 8GB is better will go for same..
Phone HDD should be atleast 128 GB, further to 256 gb is good (but not required)
10. If you have already considered a phone, then please mention the model
A: MI
Questions:-
1. Budget?
A: Mi
A: Dual Only,
A: MI
