CPU/Mobo mic problem - help needed
barcrphd
Apprentice
i use windows xp sp-2. i had problem using the sound recorder. when i attempt to record sound a blue screen will come with the message that "you are trying to use non executable memory" and it will suggest to restart the computer. after formating and reinstalling win xp sp-2, the problem with the blue screen was stopped. but there is a new problem. the sound recorder is not recording the sound. whatever i speak in mic can be heard directly in desktop speakers.
the next problem is that i cannot use the mic for voice chatting. i could call a friend (using google talk), the ring is going, but when he picks up the call, my computer restarts.
earlier also this problem was there but in a different way. earlier when the call is picked up the computer screen will go blue and the message that "you are trying to use non executable memory" will appear.
i really dont know what to do. please advice me what to do.
thanking you in anticipation.
