SudipBasu
Hi everyone,
need suggestions for my Mini ITX build core component only. I will purchase the monitor and other IO peripherals separately. I have proper gaming PC built on my playroom, need this for my bedroom. I will mainly use this to browse the internet, plying game using the steam link (streaming) and as Plex client connected to the TV (streaming video). Mainly need the suggestion for CPU/MOBO/PSU/Cabinet (Cooler Master Elite 130 Mini-ITX). suggestion for other cabinet is also welcome. I don't want to spend loads of cash here, just a bare minimum hardware to satisfy my above need.
- What is your budget?
- 25K To 30K
- Cabinet - Cooler Master Elite 130 Mini-ITX
- CPU - any compatible CPU
- Motherboard - any compatible motherboard
- GPU – Not needed
- PSU - Corsair VS550
- Ram – Need suggestion 8GB DDR4
- No Upgrade in future
- Amazon Only (Have some balance there)
- No
- General Purpose, Mainly browsing
- Gaming using steam link
- As plex client
- Gaming - 1280x720
- No
- Windows
