It seems that Motorola is working on an update to the legacy RAZR M with a new and updated Razr M HD version. This new device simply builds on the older device, updating it into late 2012 standards for a upper mid-range smartphone running on Android 4.1 Jelly Bean (Motorola recently updated their Droids with this newer version of Android from 4.0 ICS). Take the leaked specifications with a grain of salt.
Motorola Droid Razr M HD Specifications Leak
As you see, the device is a mix and match. The 3,300 mAh battery being a big surprise, as we would normally expect it to come with a Razr M HD MAXX version instead of the standard version. Never mind, this gives the device over 21 hours of talk time and 15 and a half days of standby (that's low, but talk time is amazing). This battery is Lithium Polymer type.
The CPU is a Snapdragon S4 Plus which is pretty powerful in it's dual core configuration. That with the Adreno 225 should easily power the 4.5" display carrying a HD resolution accounting for a 326 ppi pixels density, pretty good (I know I know, it's not 440 ppi like the Droid DNA).
Source
![](/proxy.php?image=http%3A%2F%2Fwww.techenclave.com%2Fnews%2Fwp-content%2Fuploads%2F2012%2F12%2FMotorola-Droid-Razr-M-HD-Specifications-Leak.jpg&hash=b6dbd01472da58e19f92775229ba80c2)
- Qualcomm Snapdragon S4 Plus MS8960 chipset
- 1.5 GHz dual core Krait CPU
- Adreno 225 GPU
- 1 GB of dual channel, DDR2 @ 500 MHz RAM
- 4.5" HD (1280*720) display, 326 ppi
- 8 GB of ROM
- 16 GB if internal storage
- micro SD, microSDHC support up to 32 GB
- 3,300 mAh rated Li-Po battery
- Android 4.1 Jelly Bean
Source
Rumored Specifications
Design
Device type: Smart phone
OS: Android (4.1) upgradeable to Android 4.2
Form Factor: Candy Bar
Dimensions: 5.15x2.52x.035
Weight: 5.22 OZ
Display
Physical size: 4.5 inches
Resoultion: 720x1280 pixels
Pixel density: 326 ppi
Technology: TFT
Colors: 16 777 216
Touchscreen: Capacitive, Multi-touch
Features: Light sensor, Proximity sensor, Scratch-resistant glass
Battery
Talk time: 21.25 hours
Stand-by time: 15.65
Capacity: 3300 mAh
Type: Li - Polymer
Hardware
System chip: Qualcomm Snapdragon S4 Plus MSM8960
Processor: Dual core, 1500 MHz, Krait
Graphics processor: Adreno 225
System memory: 1024 MB RAM (Dual-channel, 500 MHz) / DDR2 / 8192 MB ROM
Built-in storage: 16gb
Storage expansion: microSD, microSDHC up to 32 GB
Weight: 5.22 OZ
Display
Technology: TFT
Colors: 16 777 216
Battery
Capacity: 3300 mAh
Type: Li - Polymer
Hardware
