I got my PC with the following configuration
Motherboard MSI H67 E35
i5 2400
Corsair Vengeance 4 GB 1600
Corsair GS 600
The motherboard had a problem with the Intel C-State enabled there was a varying noise added on top of the white noise that is normally audible in the speakers. But when the C-state was disabled this problem did not exist.
I updated the drivers BIOS, checked the earth but the problem would go away only if I disabled the Intel C-State.I goggled the problem and found out that that kind of sound occurs when there is a problem with choke.
There is an audible high pitch noise(similar to one on my speakers) emanating from the motherboard.Couldn't locate any source of the sound.
The sound is pretty faint but it is audible when the volume is set to maximum. I tested my speakers with PSP,my old PC but that kind of chirping noise over the white noise is not audible.
So got the motherboard replaced with a new one(same model). But the new one also has the same problem so what should I do now?
i5 2400
Corsair GS 600
