MTP Device problem
! 0 t A
Forerunner
Well i have a Creative Zen Micro 5GB and recently it has stopped working on my computer specifically [ it used to work earlier]
Now when i plug it in it detects Creative Zen Mirco [i.e the balloon pops up in the bottom of the screen]. . .then the standard installation window opens. .when i follow the dialogues it leads me to an installation screen where it tries to install this as a MTP Device. .and here it fails to do so . . and i am unable to access my player or Sync it with WMP 11. . this happens when i plug my phone in MTP mode to my PC as well.
While when i do this on my friends PC. .it gets detected and ready for Sync within the second. .
Please some1 give me a solution. .i have the latest Firmware on my player which makes it a MTP device and directly Sync able with WMP.
I don't have any creative software installed on my PC [neither do my friend's PC]. .so please tell me if i require to do so. . i have windows XP SP3
It happens. Windows issue. Uninstall the player from your system and then reboot. THen connect and allow it to be detected all over again.
I must have done that like a gazzillion times already :@
All in VAIN :S
try it in linux, if it works there, then you know who to blame. MTP is a protocol, if linux honors then should windows as well.
~LT
techie_007 said:
please, help. mtp device error - Zen Vision:M - abi>>forums
Try reinstall WMP11.
Its a registry/drivers thing. A reinstall would fix it for sure :P I doubt you want to do that though. You will prob need to lean some stuff related to the drivers from ur registry. What ones exactly, dunno :ashamed: Try google more?
Thnx mate that did it !!
It was a corruption in my MTP shit watever that is. . reinstalled WMP 11 . . tadaa !!
Screw Microsoft !!! Screw Creative !!!
Thnx for all the help guys. . as usual TE comes to my rescue :clap:
