Multi-Monitor Gaming System + Office Works
AcidBurn
Apprentice
Hello Everyone,
I am building a new Multi-Monitor Gaming System, which will include 3 x Dell U2311H LCD and Dual AMD Card in Crossfire.
I already asked SMC, Delhi to quote for there best price, please have a look on my configuration and give your valuable suggestion. Budget is < 1.75 Lac
Intel Core i5 2500K CPU
Asus Maximus IV GENE-Z or GIGABYTE GA-Z68X-UD7-B3 or MSI Z68A-GD80 Motherboard
Corsair Vengeance 8gb (2X4 GB) RAM
MSI R6950 Twin Frozr II/OC x 2 for crossfire
1TB WD Caviar Black 6Gbps SATA3 + SSD (will order from USA)
Dell UltraSharp U2311H X 3 LCD
SATA DVD Writer LG/HP/Lite-On
Cooler Master Silent Pro Gold 800W
Corsair Graphite Series 600T Mid-Tower Case
Corsair H70 Liquid Cooler
APC 1500VA UPS
Razer Mamba
SteelSeries SX mousepad x 2
Windows 7 Professional 64-bit
Corsair CWC H70 Liquid Cooler for CPU
Regards
Acid
Very nice configuration.
You could get a better PSU to power that system. Also instead of the H70, you could look at the Thermalright VenX or Noctua NH-D14 (if you're okay with its size).
nice config you have selected.
two changes i would suggest
1) get gigabyte z68
2)dont waste money on mechanical 6gbps drives.
it does not make any difference in mechanical hdd.
i suggest you get normal 1-2 tb drive from caviar blue and use extra cash on ssd.
ssd on 6gbps makes real difference.
corsair force 3 series is latest to come out and its rated 550/520 and it real saturates your 6gbps ports.
dont bother to put 6gbps hdd.
i would suggest seasonic ps.
Hi RD274
If I upgrade SMPS then, I have to upgrade UPS :( which will increase our cost to 10,000+
CM Silent Pro Gold 800W is 80Plus Gold Standard PSU with a power efficiency rating of 90%...
Thanks for HDD suggestion, I want to order Intel 510 Series 120GB SSD (More reliable) but it will cost me around 18,000/-, so in meantime i will use this hard disk...
H70 is more silent, I think....
I dont know about their International warranty on SSD, but they are more reliable then Corsair, OCZ, Crucial etc...
