1. Q: What is your budget?
1. 50K
A New build
A. NONE
1. CPU - AMD 1055t
2. Motherboard - any compatible motherboard
3. GPU - MSI 5770
4. Storage - Seagate 1TB 7200 rpm
Final config
LOCAL dealer
No
1)Multi-tasking
2) gaming( but not so hardcore)
3) watching HD movies/blu-ray
4) Some software utilization but not so heavy. (Normal softwares)
5) 12 hours usage, should be giving decent power efficiency but not the worst.
Do not want to buy Asus product as I heard the after sales service in India is pathetic.
Plz suggest a good LCD of 22 inch, I am thinking of BenQ currently.
I play games like GTA4, BC2, saboteur, Napolean: Total war, COD MW2,
Arkham Asylum, Assasin's creed 2, Ashes09, NFS, Star wars series. LOTR series.
11. Q: What is your preferred monitor resolution for gaming and normal usage
1. Gaming - 1920x1080
2. Desktop - 1920x1080
1. No
1. Windows 7 64 bit
Mainly, let tell something about myself, I am a blogger. I will be using my system for atleast half a day and need a peaceful quiet processor but also powerful- performance wise because I will be using FireFox with nearly 15-20 tabs open, Office2010, some softwares like winRAR or winZIP, Vuze, BitTorrent, screen shot software in the background along with some 10 windows open. Suggest a good PSU. I do blogging and writing work most of the times, But when I am done, Want to play some games rather than sulk around. Pllzzz help with good ups also
Plzzzzzz guys help me out!!!
1. 50K
A New build
A. NONE
1. CPU - AMD 1055t
3. GPU - MSI 5770
Final config
LOCAL dealer
No
1)Multi-tasking
1. No
1. Windows 7 64 bit
