Graphic Cards Multiple Gpu Problems. Need Help Asap !
yeah they tested the GPU on another P4 system, and it worked fine with RE5 on ultra settings on 1024X768
but i'm still unable to run it on mine, purchased a corsair CX500, it handled a 6850 for three hours straight in front of me, so i don't think that's the problem. changed the mobo to a MSI G41M-P26 and a 2 GB DDR3 RAM, applied fresh layer of heat sink compound, re-installed win 7, but still no luck { WTF ??? }
Help guys please !!!
I think it's a gpu problem . You mentioned that HD6770 has 775 mhz as refference clock . No , HD6770's refference clocks are 850 core and 1200 memory . Can you link us the gpu-z screenshot ? Also try oc'ing the CPU , 2.5 ghz seems low for bfbc 2 (i've heard your board is good for oc'ing) . Now after upgrading to 2gb , do you notice decrease in load times ? If not , please mention hard disk specs . Old and/slow hard drive can be attributed to long load times
