Good to see a Beautiful Overkill PC build.
Looks Amazing.
All the Specs are top notch.
Except the RAM.
Please don't mind, But I think 4400Mhz or 4600Mhz would have been better for your high end CPU and GPU.
Also, I am a little curious about the 4 WD Purple HDDs.
I haven't seen anyone use WD purples in their PC build. And there are valid reasons for not using those purple drives to save your precious data.
Read this.
Data Recovery from QNAP NAS (WD Purple X 2) | Data Recovery Ireland
We recently recovered data from a QNAP TS-253 Pro. This is a popular two-bay NAS device which uses the QTS operating system. This particular NAS was using two WD Purple (WD20PURX) S-ATA disksdatarecoveryireland.ie
THank you mate , let me answer point by point
1) Right now I have 4000mhz (running at 3600mhz) Tforce xtreem ARGB Ram 8 x 4gb kit , anything higher than 3600mhz is a hit of a miss with Ryzen CPUs , Intels are a different story, and i decided to use 4 sticks for aesthetic reasons, as this build is a mix of performance and aesthetics
2) 4 x 4 WD purple drives are used in my case for data archival purposes the hot data would always exist on 2 x 1tb Gen4 NVMe drives , even if it fails doesnt matter, i will be upgrading these drives to 16tb x 2 soon anyways.
There are a lot of other changes happening soon
Thank you mateGreat Stuff. Awesome build.
