PC Peripherals My V8's fan went bust. Need replacement suggestions.
mjumrani
Explorer
Hey guys.
A few days ago my CM V8's fan went bust. Made a lot of sound and it stopped after that. Don't exactly know what happened to it.
So now I need to get a new 120mm fan.
I was wondering should I get the same one that just went bust on me or do I get a delta or scythe or something else.
The old fan had 90CFM I think.
I don't have much of an idea about fans, so I need your help so that I don't buy the wrong fan.
TIA :)
you can fix a 120 mm on the same,a 90cfm or more 120mm fan can be purchased locally,other brands fan can also be fixed, as cooler master does not makes any fans themselves.
I would suggest trying the cm blademaster fans--i use 2 of them 92mm(hsf)+120mm(case fan) -425-450rs a piece for 120mm fans.
