I use an Acer 27 inch (2550x1440) monitor and find it too small for my work.
+1Simple solution - buy two. This is what I have. Double the real estate and you don't have to break the bank. High quality 4k 30/32 inchers are way too expensive and won't fit in the 50k budget.
Just wondering why 27 inch is not enough? Use some emulators and VM side by side? I generally find adding a second screen much benefical then increasing screen size
How have you set yours up? I h
ad given dual monitor a half hearted try (two monitors/different sizes) and didn't like it much. A shiny screen in peripheral vision was distracting. Not to talk about the need to turn the neck each time I want to look at another screen.
Do you have a main monitor in front and a subsidiary one on the side (at an angle?). Is the subsidiary one only used for parking windows or do you work actively on both? Are both in landscape?
Sorry for too many questions. I am just trying to figure out if I was doing something wrong. I was also wondering if a three monitor setup might be better than two.
Sounds interesting. I will definitely check this one out. Any idea how bad the glare is? I don't want to hurt my eyes any more than I need to.You are better off getting a used Samsung MU series 4k TV for around ~30k, which can be used as monitor
It's actually, pretty good. Monitors and TVs are basically the same things, with different port setups, and you can always fiddle with settings to make it comfortable for your choice.Sounds interesting. I will definitely check this one out. Any idea how bad the glare is? I don't want to hurt my eyes any more than I need to.
If you can run putty, why don't you run an xserver on your local machine and export a display from there? It'll make development much faster.
Although, after tying with multiple monitors, big TVs etc. I finally settled using my 15" Mac screen with desktop switching, it's easy, I take it everywhere, I don't feel limited when I am not around my monitors n stuff. So, that is what I use now after trying everything!
echo "set wrap" >> .viminfoWhen I started programming (on vt100), everyone knew that the maximum line width was 80 character. These days I often have to maximize the window to read code without line wrap. This becomes specially painful when reviewing diffs (one of the main reasons I why I want a bigger screen).
No dude. They arent. The compression settings are different. Check the chroma values before buying any TVs to work as monitors with text, or your eyes will bleed (figuratively).It's actually, pretty good. Monitors and TVs are basically the same things, with different port setups, and you can always fiddle with settings to make it comfortable for your choice.
