shatrughan
Guys i am going to buy a new PC in next a weeks time, so need your inputs on this one
Q: What is your budget?
40K
I won’t be keeping anything from my old config.
CPU – both intel and amd will work
GPU – dont know abt which one to buy
HDD – WD Only
Monitor – Should be HD and 19’ – 22'
This is what it’s gonna be for quite a few years to come.
Mumbai and online Purchase from ICT or TE market
Q: Would you consider buying second hand hardware from the TE market
No
Maya
Gaming
Browsing
Watching HD movies
No
Strategy – Supreme Commander
Racing – Rollcage, NFS Series
FPS – Counter Strike : Source
Gaming - 1280x728
Desktop - 1440x900
No
Windows 7 64 bit
Windows 7 32 bit
Thanx for all your help
40K
HDD – WD Only
No
Maya
Gaming
Browsing
Watching HD movies
No
Gaming - 1280x728
Desktop - 1440x900
No
Windows 7 64 bit
Windows 7 32 bit
