raksrules
Elite
Need phone for my maternal aunty.
1. Q: Budget?
A: 6k Max - Cannot go over, cheaper the better
2. Q: Preferred Form Factor (flip, bar, slider)?
A: Bar
3. Q: Preferred display type?
A: Any
4. Q: Do you have any brand preference or dislike? Please name them.
A: Nokia preferred mostly, but other options can be considered
5. Q: Preferred input method (Touchscreen, QWERTY, etc.)?
A: NO QWERTY and NO Touchscreen, only normal keypad
6. Q: Camera required or not? If required, please specify type like front camera/flash/etc.
A: Not necessary
7. Q: Preferred operating system? (Android, Symbian, iOS, Windows Phone etc).
A: Anything
8. Q: Preferred connectivity options? (3G, Wifi, Edge etc).
A: Don't Care
9. Q: What is your intended use for this phone(internet, camera, multimedia, mails, etc)?
A: Normal call receiving and dialing, music and FM radio. GPRS /EDGE will never be used.
10. Q: Any other requirements?
A: Antenna should be very good to get signals in low signal areas too.
11. Q: If you have already considered a phone then please mention the model.
A: Not really as am confused but even if the phone costs 2K with features required then i am fine, cheaper the better.
Also suggest from where to buy will be my best best with the best discount
1. Q: Budget?
A: Bar
A: Any
A: Not necessary
A: Anything
A: Don't Care
