X-jo
I would like to buy a PC and that should/must be able to emulate PCSX2(playable) games at max speed with good amount of fps. I would also be playing PC games but PCSX2 is the top priority.
http://forums.pcsx2.net/Thread-Sticky-Will-PCSX2-run-fast-on-my-computer is the thread which states the requirement possibilities for pcsx2 to run well.
This will be my first desktop as I just have a laptop. (My friend would want a similar config in his laptop too http://www.techenclave.com/community/threads/need-a-rig-specially-for-running-pcsx2.149959/)
- What is your budget?
- 35k. 40k only if the requirements I need don't meet 35k.
- None
- None
- I would need everything that a PC needs from smps, keyboard, mouse, ups etc
- Anything that meets the below following , if I can get the maximum req at this budget then awesome else i would want the recommended req
Minumum Req.
C2D or AMD x2~ at 3.0 Ghz and gddr2 equivalent Video card(Except 64-bit bandwidth video card)
Recommended Req.
For i5 or i7 at 3.2Ghz(Except P4,PDC,C2D,C2Q,i3),For AMD x2~ at 4.0Ghz and gddr5 equivalent video card
Maximum Req.
i7 Extreme series unlocked by 5Ghz and gddr5~ Super-OC edition video card or Nvidia GTX-Ti Super-OC edition and excess of 256-bit bandwidth
Priority Req. :
*If your desktop/laptop's has a C2D,Core-i BUT it's video card is a Intel-GMA,Gxx express chipset,Sandy Bridge's intergrated video card or other built-ined
VGA that takes priority of a failure system requirement.
**If your desktop/laptop's video card is gddr2,gddr3,gddr5 or other best video card BUT it's CPU is a Dual/quad-core less than 2.66Ghz, a
Pentium 3,4 or AMD without X,athlon 64,Turion,Celpron,486,586,Intel-Atom,Intel-Centrino,Intel-Celeron,Intel-Core-Solo,ALL types of Netbook or other single-core
CPU that takes priority of a failure system requirement..
- Yes, would like to have this for 2 years minimum
- Hyderabad
- Open to online purchase
- No
- Gaming ie emulating console games especially PCSX2
- Browsing
- Download rig, 24x7 operation
- Watching HD movies
- Any brand which will meet my requirements here http://forums.pcsx2.net/Thread-Sticky-Will-PCSX2-run-fast-on-my-computer . (first post in that thread)
- games on PCSX2
- STEAM games
- Virtua Tennis, racing and strategy games
- Any which is best fit for my requirements
- No
- Windows 7 (Primary)
- Linux - Linux Mint(Secondary, dual boot)
