X-jo
This is for a friend.
(I too have the same needs but for a PC and that thread is here http://www.techenclave.com/community/threads/need-a-rig-specially-for-running-pcsx2.149958/)
My friend would like to buy a Laptop and that should/must be able to emulate PCSX2(playable) games at max speed with good amount of fps. He would also be playing PC games but PCSX2 is the top priority.
http://forums.pcsx2.net/Thread-Sticky-Will-PCSX2-run-fast-on-my-computer is the thread which states the requirement possibilities for pcsx2 to run well.
- What's your Budget? ( 40k )
- What will be your primary usage for the notebook be?
- Gaming ie emulating console games especially PCSX2, STEAM games, PC games
- Browsing
- Download rig, 24x7 operation
- Watching HD movies
- What size and weight considerations do you have? (Any)
- Any brand that you prefer, or any brand that you detest? (Any)
- Any other considerations? (better cooling, If it has the 2-3yr replacement thingy which dell gives then awesome), also
Laptop Processors:
We do not recommend the use of any laptop machines on the emulator unless otherwise mentioned above, if it supports SSE2 then it may work. if it does not have SSE2 then it is likely it will be extremely slow and have emulator compatibility problems. - Will buy this online or from hyderabad
- OS - Windows and Linux dualboot
