Questions
- What is your budget?
- 60-70K
- N/A
- N/A
- CPU - Ryzen?
- Motherboard - any compatible motherboard (10gig networking preferred but not required)
- GPU - Not required
- PSU - Any compatible one
- RAM: 16GB Minimum or more
- HDD: 240-500GB SSD for boot and 4TB HDD for storage
- Cabinet: Please recommend a compact one
- Monitor: Not required
- KB/Mouse: Not required
- No upgrade plans
- Online
- Local vendor if they have stock
- Would you consider buying a second-hand hardware from the TE market
- No
- Need a system to run 3 non-critical VM's for a client. Would prefer to have dual SSD's in RAID-1 for boot if possible.
- N/A
- None
- N/A
- No
- Proxmox or XenServer
