Need advice for Chasis
Expectations:
1. MID Tower.
2. Nice Cooling ( If Extra Fans can be bought, that is ok but provisions must be there.)
3. Noise level should be low ( As low as possible)
4. No LED's or eye candy. ( With No lights it should be as dark as possible)
5. Decent Cable management and dust proof.
6 BUDGET - 3000 INR ( Can go for 250 or 300 more if its that good)
Current Components:
1. Corsair 650TX v2
2. HD 4670 with stock cooler
3. Intel motherboard / processor with stock cooler.
4. 2 Hard disks (Sata)
5. One DVD writer
I am looking at NZXT Gamma, but i dont know how noise proof it would be if i fit it with cooling fans and also the cable management. Is there any other cabinet that exceeds my expectations on that budget ?
Awaiting suggestion.
Expectations:
1. MID Tower.
Current Components:
1. Corsair 650TX v2
5. One DVD writer
