harpreet89
I've been noticing this thing for quite a while that the temperature of my system is quite high.:crash:
My system config is:
Intel Core 2 Duo E6300 @ 1.86GHz (stock speed)
2 hard drives(WD 500+WD 160)
Asus P5B-TMX motherboard
ATI 4670HD 1GB
Stock Heat-sink (but its not like other Intel heat-sink..its a bit different as its HCL-Busybee,so its size is slightly larger than original Intel Heat-sink.)
So,my problem is that the temperature shoots upto around 76-80C in load and my second hard drive(WD 160) is as hot as a furnace:-[.
So,is there any way to reduce these temps.
And i think this might be due to the summer of Delhi...its too hot here...
Here is the screenshot of SpeedFan of my system with no-load state and in load state.
ATI 4670HD 1GB
