I'm building a new PC with i5 12400F (Planning to upgrade the cooler in future too), ASUS prime b660m-a d4, RTX 3070 (Currently have GTX 960 but will upgrade the GPU in the future), 16gb ram (Might upgrade later), I already have 1 SSD and 2 HDD so i want to use that too.
I had previously picked Deepcool CC560 as my cabinet but the seller cancelled the order i can't find it at a reasonable price from a trusted site now.
Now i'm looking for a new Cabinet, my requirements are: Airflow, should fit my components easily and most importantly,
No RGB, or atleast RGB that can be turned off. The only reason i went with CC560 is because it atleast had 1 static color light on fans. All the other cabinets i see have RGB fans which i hate.
I'm fine with going with a Cabinet that does not come with fans and get the fans separately provided they don't have RGB as long as it falls in my budget.
My budget is 5k for both cabinet and fans
