PC Peripherals Need Cabinet fans..which options ?
Amol
Inactive
Discoverer
I need a couple of cabinet fans , 120 mm preferred, and with silent and yet powerful operation. Any recommendations ? Where do i buy these ?
Does ur cabinet support 120mm? First check that b4 buying. Good cheap ones are sunon. However you could spend a bit more and get panaflos that offer really good airflow at low noise levels. Even the coolermaster fans offer decent bang for the buck (450bucks for led fans). I have 3 panaflos(2 intake, 1 exhaust) and two cooler masters(one chimney, one ram cooler) in my cabby and they do the job really well ;). All of these are 80mm though as my cabby doesnt support anything bigger without serious modding!
I have a sunon, and it sounds like a vacuum cleaner. I am not sure if this is a 120 mm or a 80 mm, lol, no idea about fans. Where do i buy panaflow fans ?
@Amol - check this post of mine - I have left an address for a shop selling fans at Lamington Road Mumbai - they get many good brands - including Panaflo Sunon Papst Nidec and others.
http://www.techenclave.com/forums/63935-post1.html
@amol: It depends really upon what the fan is rated at... I have a 92mm sunon that is absolutely silent. Yup Papst is a really good as well. Easy are u talking abt this atlantic shop in tara temple lane?
amol is in gujarat :S
if u have a typicab cabby, its 80mm for sure....so get sunon 80mms....i use 2x40CFM 80mm sunons on mine...get uber airflow in the cabby :D
YUP.... and I think they will ship to other cities. I have heard them getting out of town phone calls ordering fans when I have been at their shop.
